February 7, 2003, 14:59 |
problem with fluent in batch mode
hello ,
here is my problem: I try to use gambit and fluent in a batch mode and get the automatisation of the process: Gambit reads a journal file I have written and exports the mesh (mesh.cas). Then Fluent has to read this mesh, check the grid, choose the solver,.... I would like to know how to write the journal to choose the solver.. I have no problem for the reading and the checking of the mesh. When I write: define/models/solver, I don' t know what to write to choose Coupled for the Solver, Implicit for the Formulation, 3D for the Space, Steady for the Time and Absolute for the Velocity Formulation. Thank you for your help Pat |
February 12, 2003, 02:45 |
Re: problem with fluent in batch mode
How about the following expression. define/models/solver/c-e yes(if you want to choose coupled-explicit solver). Regards, Keil |
February 13, 2003, 14:14 |
I had found the solution, but thank you for your answer, Keil.
Regards, Pat |
A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 11:26 |
fluent convergence problem | josip76 | FLUENT | 0 | May 26, 2011 21:08 |
DPM model in parallel batch mode | Prashanth | FLUENT | 2 | March 6, 2009 08:54 |
fluent stops batch mode on error | Ralf Schmidt | FLUENT | 1 | March 1, 2008 11:35 |
parallel mode - small problem? | co2 | FLUENT | 2 | June 2, 2004 00:47 |
