Flow interaction per chemistry update in FLUENT .
Old   February 4, 2003, 16:25
Default Flow interaction per chemistry update in FLUENT .
peter gelblum
Greetings. Did any one implement the option of Flow iteration per chemistry update in FLUENT 6 ? This option is mentioned in the respective HELP panel for Define-->models-->species-->turbulance-chemistry interaction, but not given!.
Thanks for any respective literature/dissertaion refference, i.e. directly related to FLUENT.
Thanks
Peter
Old   February 5, 2003, 06:50
Default Re: Flow interaction per chemistry update in FLUEN
Erwin
I think you need to select the Eddy Dissipation Concept first before you can select this option.
Old   February 5, 2003, 11:38
peter gelblum
Erwin Thanks.
Yes I did select EDC 1st but, the EDC model window (i.e. within the spEcies model)does not portray an option of "Flow Iterations per Chemistry Update", COTRARY TO WHAT Is indicated in the respective HELP panel! That is exextly the point of my note and my search for a respective FLUENT related UDF or FLUENT inherent nobe!
Peter .
Old   February 6, 2003, 04:43
Erwin
I checked, I have seen this species menu behave a bit wacky in the past. Indeed, the 'flow iterations' thing does not pop up the first time. First you have to click OK, then it should be there when you go back again.
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
reversed flow in unsteady simulation with dynamic mesh (fluent 12.1) zhaoyu_001 FLUENT 0 April 7, 2010 01:24
swirling flow in simpleFoam compared with FLUENT belinda OpenFOAM Running, Solving & CFD 0 November 2, 2009 04:57
Unsteady Flow in FLUENT Vidya Raja FLUENT 0 November 1, 2005 18:54
Compressible flow simulation using FLUENT arun Main CFD Forum 0 February 16, 2004 16:44
