Reading Data from a file
Old   February 3, 2003, 22:39
Default Reading Data from a file
Pravir
Hi!!!
I want to read particle injections from a file by defining the points from where they are to be injected. Could anyone tell me the following points:
(1) What language shud I write my code in? (2) How will FLUENT know that the data points which I created are the values it is looking for? In other words is there any format in which I have to write my data in the file so that FLUENT understand as soon as it reads the data. Besdies the coordinate points I also have to specify the diameter and mass flow rate of the particles to be injected.
Thanks
Pravir
Old   February 4, 2003, 03:13
Default Re: Reading Data from a file
Markus
Hi Pavir
All you have to do is to use the File-option for setting Particle injections.The syntax for this is given in section 19.9.2 of the userguide.
br Markus
Old   February 4, 2003, 10:46
Pravir
If I have 2000 particles then do I have to write (( x y z u v w diameter temperature mass-flow) name ) it 2000 number of times. What type of file would this be??? Is this a text(notepad) file???
Old   February 16, 2003, 05:57
varshavian
i have a problem like this. please tell me if u understand. thanks bye varshavian@mehr.sharif.edu
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 09:33
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
