Meshing problem
Old   January 31, 2003, 06:57
Default Meshing problem
John
If you split up your volume into parts, so that it's easier to mesh, do you have to put them back together after the mesh is applied to allow the fluid to flow, e.g i split a pipe into two parts and meshed them, same shape/spacing, separately and the flow was distrupted. Why was this do the grid have to be connected and if so how do you do this?
Cheers John
Old   January 31, 2003, 12:37
Default Re: Meshing problem
Jurgen
If you have two separate face where both volumes shoudl be connected, FLUENT assumed these to be a wall, i.e. you need to connect those faces with each other. If you do that you will see that one face is deleted and the two volumes share this remaining face. Regards, Jürgen
Old   January 31, 2003, 13:08
Eric R.
John,
Another approach is to group both fluid volumes under the same "FLUID" in 'specify continuum type.'
For example, my geometry was decomposed into 36 different volumes (all comprising the same fluid region). You can set the boundary conditions (faces) in Gambit, but can also set the fluid continuum (volumes).
Hope this helps.
-Eric R.
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 19, 2023 00:49
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 08:21
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 21:03
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
