Problem with DPM model
Old   January 29, 2003, 20:54
Default Problem with DPM model
cwflying
Hi everyone,I am now using DPM modele to simulate particle movement in a hydrocyclone. In terms of hydrocyclone, it has one velocity inlet and two outflow outlets( I have set the flow weight already). First I simulate fluid flow in hydrocyclone using RSM modele( because it is strong swirling flow) then add particle injection at inlet,assuming particles having the same velocity with fluid flow at inlet, using DPM modele. The problem is: when I track particles, I find the particles only escape at inlet, not two outlets!
(two axisymetrical dimension,inlet velocity for example u=0,v=-0.2m/s, w=2m/s)
Old   January 30, 2003, 03:56
Default Re: Problem with DPM model
Jurgen
Some ideas: are the outlets set to escape in Boundary Conditions? You can also specify the boundary at which the particles escape. I think that is done under Report-> Discrete Phase Model. Hope this helps, Jürgen
Old   January 30, 2003, 05:43
cwflying
I have already set the escape boundary conditions at two outlets and inlet, the wall B.C is set to reflect.
Old   January 30, 2003, 05:50
dag
Try setting your inlet face as reflect instead of escape. I would initially guess the centrifugal field is large enough to instantly move your particles out through the inlet before they enters the domain.
In addition Fluent has a bug when it comes 2-D acisymmetric particle tracking in cyclones (and probably other type of geometries), where particles lighter than the fluid move towards the wall. You can easily check if this is part of your problem with a 3-D calc of the same geometry (take a 5 deg rotational symmetric 3 D example of the same geometry).
Old   January 30, 2003, 06:01
cwflying
Thank you, I have also tried setting inlet B.C to be reflect, but it still does not work. And in my case particle is about 2000kg/m~3, fuild flow is water.
Old   January 31, 2003, 12:25
bala
Hi, First you solve for the continuous phase. After some iterations, just enable the DPM model and try.
Regards, bala
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 10:39
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 13:00
lenght and number of nodes for an orifice meter flow problem - k-eps model fofo FLUENT 0 November 15, 2009 04:49
problem about DPM of cyclone separator simulation jason FLUENT 4 November 12, 2007 04:15
how to do with the DPM problem? x.p.lee FLUENT 1 June 26, 2003 14:07
