Front Tracking and VOF
Old   January 27, 2003, 01:06
Default Front Tracking and VOF
Seeker01
How to use Fluent to do front tracking, such as filling of a mold CAVITY?
Can Fluent do the simulation with VOF method for free surface flow ? How ?
Old   January 30, 2003, 11:14
Default Re: Front Tracking and VOF
Ergin Esirgemez
FLUENT 6.0 has a cabability of solving free surface flow by using VOF method. For this purpose, you must built a grid for water and air part seperately. I mean that Your medel must have two inlet, one is for air and the other is for water, and your model must have two outlet, one is for water part and the other is for air part. Actually the boundary condition is related to the problem. But I can say that FLUENT 6.0 is a good tool for free surface problem, and you can solve this type of problem by using VOF method. When you initialize the problem, use the air inlet part, and then use "patch" command to indicate the level of water. First adapt + region part, and then mark the grids which are in water part, then go initialize + patch and then patch the marked region, by selecting the region and volume of water phase and writing 1 for the value. Then you can solve ... good luck
Old   February 6, 2003, 23:52
phd_y2k2001@yahoo.com
You may want to read some papers before you start simulations. If you search 'web of science' you will find quite few papers using VOF to model this kind of application.
LES + VOF + Particle tracking mittal OpenFOAM Running, Solving & CFD 5 October 21, 2010 20:32
VOF Interface Tracking Algorithm CFDtoy FLUENT 4 August 5, 2010 05:41
LES + VOF + Particle tracking mittal OpenFOAM 0 June 29, 2010 07:41
Best front tracking method for surface evaporation Komkamol Main CFD Forum 0 July 17, 2009 11:23
Melt Front Tracking in Transfer Molding Alex FLUENT 0 August 2, 2008 22:43
