January 10, 2003, 08:10 |
udf c compile
Hi all, Quick question: Interpreted udf's work in fluent without me having a C compiler on my computer (Windows if it makes a difference), do compiled udf's work or do I need a compiler? I need to know so that I can start buying one if necesary while I read how to use them. Thanks, Rat
January 10, 2003, 20:32 |
Re: udf c compile
I don't think so u need extra C compiler cause u can write the program on grendel console window with VI commads or u can do it on notepad then upload it to working directory and modify with VI commands.
bye Alamgir |
January 14, 2003, 10:05 |
Re: udf c compile
For compiled UDF, you have to have a compiler on your computer. For Unix/Linux some cpp compiler will do. In order to use compiled UDF on windows, you'll need MS Visual C 6.0.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Error compile file udf | czfluent | Fluent UDF and Scheme Programming | 24 | September 26, 2009 13:24 |
udf compile in parallel system | tahereh | FLUENT | 1 | December 9, 2008 09:48 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
compile the UDF | Li Jingping | FLUENT | 2 | April 14, 2003 21:18 |
