January 9, 2003, 17:11 |
Boundry Conditions
I made a geometry in Gambit and then created a neutral file and now i exported it to Fluent to solve it.I am able to define materials. My problem is that i am not able to defien boundary conditions, what do i need to do to give boundary conditions under the command define.
January 10, 2003, 02:24 |
Re: Boundry Conditions
Parshant, you should define the boundary condition type in the gambit,just like the inlet,outlet,and wall the liquid region and so on.Then you can specify the value of the boundary condition,just like the inlet velocity is 0.5m/s and the pressure outlet is zero[0].I hope I did not confuse you!
regards zhhuang |
January 10, 2003, 21:18 |
Parshant
U should follow Zhhuang, One thing I need to mention before exporting mesh u need to specify the boundary conditions (BC) in GAMBIT. and the values of that BC u should introduce in Fluent. zhhuang might miss in the last line a word FLUENT. BYE ALAMGIR |
3D airfoil boundry conditions | sarat | FLUENT | 1 | July 15, 2009 09:09 |
selection of model &setting boundry conditions | rajesh | FLUENT | 0 | March 2, 2008 09:22 |
Boundry conditions!!!! | Zaher | CFX | 2 | March 16, 2004 10:25 |
Boundry Conditions | Parshant Dhand | FLUENT | 2 | January 10, 2003 21:25 |
Non constant boundry conditions | Mounir | FLUENT | 1 | February 14, 2001 09:05 |
