VOF for free surface
Old   December 30, 2002, 22:46
Default VOF for free surface
qb Jiang
I am a newer for Fluent. I want to model the coating process with Fluent( I know FIDAP works this problem, but I don't have FIDAP available.)
I set the BC of free surface as pressure inlet, the BC of fluid into the coater as pressure inlet, the substrate as a moving wall and the left BC as outlet. Then I patch a volume of air arbitrarily as the initial phase arrangement and run with unsteady state and zero velocity for all the fluids. However, every time the error is floating point exception(underflow). I don't know how to deal with it.
Many thanks. I'm looking to hearing from you.
qb Jiang
Old   January 17, 2003, 09:05
Default Re: VOF for free surface
mm
did you mean you set your outlet as an OUTFLOW?. If so, try changing to PRESSURE-OUTLET. Also try PRessure Inlet to Velocity Inlet if you have the velocity profiles at the inlet.
Check the grid as well!
Cheers mm
Old   January 20, 2003, 17:13
qb Jiang
Hi, Thank you for your reply.
I had these tries, but it still doesn't work. I don't know why. I set the outlet as velocity inlet, change the pressure inlet into velocity inlet. There is nothing wrong with the mesh. I wonder if the problem lies in that the dimension is too small(50-220 micro)?
Qibo
VOF & Variable Surface Tension in FLUENT SeamusTCD FLUENT 13 June 18, 2022 02:51
surface monitors in VOF prashanthreddyh FLUENT 2 September 29, 2010 13:07
VOF and Free surface model...are they same? Kushagra CFX 1 November 14, 2008 13:36
How to monitor the surface height of fluid in VOF davidyin FLUENT 0 September 1, 2008 05:14
Surface tension in VOF chapelle FLUENT 0 October 31, 2005 03:27
