Outlet velocity boundary condition
Old   December 11, 2002, 08:36
Default Outlet velocity boundary condition
Jay
Hi there I am trying to use outlet velocity BC for my ASMM in Fluent 6. In my model, I have one inlet and two outlets BC. I have to maintain a ratio between these two outlets. I can use negative flow velocity BC for one outlet and pressure outlet for other. However I have to specify the volume fraction at the outlet velocity BC. But I do not have the value. Is there anyway to specify outlet flow velocity condition.
Thanks for your help and looking forward to hearing from you.
Regards Jay
Old   December 13, 2002, 02:58
Default Re: Outlet velocity boundary condition
Atul T. Shinde
Dear Jay, At inelt, give whatever avaialable. At one outlet,use Outflow condition and at the other outlet can go for pressure condition. Based on this solution, u will have the idea of volume fraction at each outlet. Try out.
Old   December 13, 2002, 07:32
Jay
Thanks Atul.
Yes, I can find the volume fraction the way you suggested. However, in my case I have to maintain a ratio between to outlet (recycle ratio).
Thanks Jay
Old   December 13, 2002, 19:07
Amid Naz
Using velocity outlet means the flow is incompressible. Therefore, the the volume fraction at the outlet can be determined by the area ratio directly..Using outflow BC is Ideal for the case.GOOD LUCK.
Old   December 15, 2002, 09:27
rk
You should never use the combination of velocity inlet, pressure outlet & outflow if you have one inlet & 2 outlets. You can use velocity inlet & 2 pressure outlets or velocity inlet & 2 outflow conditions.
Since you don't know the fraction of mass flow going out, you should know atleast the pressures at the outlets. This will automatically calculates the percentage massflow out!
Thanks,
rk
Outlet boundary condition for wave flume with interFoam solver Arnoldinho OpenFOAM 9 July 10, 2018 06:15
How to set the Heat Flux boundary condition at Outlet creddy_trddc CFX 3 September 21, 2011 08:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Implications for heat transfer when outlet pressure boundary condition used Blob CFX 2 March 26, 2009 07:22
Outlet boundary condition CN FLUENT 6 May 22, 2005 10:37
