November 29, 2002, 23:52 |
an easy question about gambit
When i export the mesh file from gambit,how can i chang the saved directory ? thank you very much!
November 30, 2002, 02:06 |
Re: an easy question about gambit
do the following: save as, then you will fins the current directory where you saved before or from where you ran gambit. Find the directory ending with double dot (..), most probably the second in the list from the top. Double click that, u will go down one directory.. so if u want to go down, again double click the one with .., to go up a directory, double click the directory.
Alternatively, type the directory location, then slash, then file name. U can also cut and paste the directory name from the Unix terminal. Hope this is what you are looking for. Nancy |
December 2, 2002, 04:33 |
it's easy. you can select your favorite directory by browser.
December 3, 2002, 00:58 |
Save anywhere then use vi command: cp <file> .. \dir or use transfer file window and copy/paste just like windows explorer or drag the file and release it to your destination folder.
Alamgir |
Easy GAMBIT question | noName | FLUENT | 1 | March 31, 2005 03:09 |
Gambit question | HP | FLUENT | 8 | March 4, 2005 09:32 |
Question on Gambit. | Sham | FLUENT | 2 | February 15, 2005 21:07 |
Easy question | Confused | Main CFD Forum | 4 | May 22, 2004 03:14 |
GAMBIT Question | Eric | FLUENT | 2 | February 28, 2002 23:24 |
