modeling a fluidized bed??
Old   November 28, 2002, 22:52
Default modeling a fluidized bed??
Maxim
good day everone,
I am a rookie in fluent and gambit, no need helps!!
how can i model a 2d fluidized bed using gambit??
my bed dimension should be 2.5cm wide, 6cm depth. with 10 layer of particle size 0.1mm. Gas- solid system
I am now vey confusing about how to define the bondary condition. from the FLUENT help content, i can use the pressure inlet as free surface, so the pressure inlet i should input 1 atm??
how about the bottom plate which use to allow the fluid flow in?? what bondary type shall i use??
THANK ALOT
Old   November 30, 2002, 15:45
Default Re: modeling a fluidized bed??
ravi varma
are you looking at mixing in a fluidised bed?
Old   January 5, 2003, 23:27
hlq
where can i obtain the example of fludized bed
expansion of bed in fluidized bed achy7pch FLUENT 7 August 10, 2024 04:33
Fluidized bed Modeling Shahed_iasir FLUENT 3 November 28, 2012 08:52
Fluidized bed modeling Kartus CFX 9 June 30, 2011 05:41
Fluidized bed simulation VS particle tracking windhair CFX 2 June 28, 2011 22:10
Fluidized bed simulation Siaw Khur CFX 3 July 28, 2010 15:42
