Coordinate System
Old   November 20, 2002, 00:43
Default Coordinate System
Pravesh kumar
hi I needed your immediate help.I am having my geometry in Gambit in X-Y plane.I want to know when i am having my Geometry in fourth coordinate whether i should put gravitational acceleration (g) 9.81 or -9.81. Your immediate help is required. With my warm personel Regards pravesh
Old   November 20, 2002, 04:28
Default Re: Coordinate System
gavin
If I understand your question correctly, you should have 'g' working opposite to the postive y direction, therefore it will be -9.81 m/s^2
Old   November 20, 2002, 12:29
Pravesh kumar
hi But I having my geometry in fourth coordinate i.e +X,-Y As I have already taken -Y dirn so i am not sure whether to put one more -ve for the downward dirn of gravitational acceleration(g).
Thanks for replying.
Old   November 20, 2002, 13:38
Erwin
Just check in Fluent in which direction 'the apple should fall'; in the positive y direction or the negative one. If it is the negative y direction, gravity is -9.81 otherwise +9.81.
Old   November 20, 2002, 13:49
Pravesh Kumar
Dear Erwin As i am having my geometry in fourth coordinate (ie +X and -Y.).As the apple will fall downward ie -Y dirn and i have already taken the -Y dirn in coordinate system so i am not sure whether i should put g as 9.81 or -9.81. Your help is needed. Thanks
Old   November 21, 2002, 05:18
Erwin
Your gravity is in -Y direction, so fill in -9.81. It doesn't matter in which quadrant you make your grid, +Y still goes up, -Y still goes down.
To see for yourself: read the grid into Fluent. Display the grid. Under Display/Options menu, turn on the 'Display Axis' option. Look at your grid. Decide in which direction gravity acts.
Old   November 24, 2002, 01:53
mahdi saniee nezhad
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Old   November 26, 2002, 10:50
Pravesh Kumar
Dear Erwin I can't find 'Display Axis' panel as told by you.I am using fluent6.Plz elaborate. Under Display/Options menu, turn on the 'Display Axis' option.
Thanks
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Creating Coordinate System ashtonJ CFX 0 February 17, 2011 22:07
Coordinate System selim CFX 1 October 26, 2007 22:08
Equation in which coordinate system zubin Main CFD Forum 8 April 30, 2004 11:33
Coordinate system Franch Siemens 2 March 6, 2002 08:56
