Injection of partical into flow field
Old   November 19, 2002, 05:12
Default Injection of partical into flow field
M.Mahendran
Hai all, I have studied particle deposition mechanism in the flow field .I am having problem with injection of particle in the flow field. Now I am introducing group of particle streams in the compressible flow field. In the flow field I have introduced small perturbation but the particle streams are separated before the perturbation.
Can anybody give me some ideas to overcome this? I would really appreciate the help.
thank you
M.Mahendran
Old   November 19, 2002, 23:58
Default Re: Injection of partical into flow field
Alamgir
First thing, do u wanna introduce particle as a pulse or continuous injections. r u running multiphase flow? if so, then which one? u have to run multiphase mixture model or eularian model, then primany phase would be compressible one and the secondary should be particles. and put the boundary condition for continuous injection. outher wise u have to run trasient flow in multiphase modelling and write a UDF for the pulse.
anything more?
Alamgir
Old   November 24, 2002, 01:54
mahdi saniee nezhad
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Porous domain in a flow field rikio CFX 7 August 25, 2009 23:39
flow field residuals into posdat? nicola Siemens 0 February 9, 2007 11:54
axisymmetric main flow + injection Stephan FLUENT 1 January 19, 2006 12:43
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
