Problems with exporting Gambit mesh to Fluent
Old   November 14, 2002, 10:07
Default Problems with exporting Gambit mesh to Fluent
Alex Mozharov
Hello ! I try to export mesh file from Gambit v1.3 to Fluent 5.4 but i have some problems . Geometry and grid were valid in Gambit but it are corrupted after export to Fluent. Please , anybody tell me what I can to do ? ( Sorry for bad English )
sincerelly yours , Alex
Old   November 15, 2002, 03:32
Default Re: Problems with exporting Gambit mesh to Fluent
zhhuang
firstly,ensure you have export the mesh successed,the gambit will give you the result.Secondly,check the your choice,did you select the 2D for 3D problem or choose the 3D for 2D problem.
Old   November 15, 2002, 09:02
ravi varma
also check if solver you have selected is FLUENT 5/6 when exporting the mesh from Gambit. if you have 2 or more geometries, check the interface between the faces.
Old   November 18, 2002, 22:39
revalin herdianto
When you export your mesh to fluent, please make sure that your t-filter works. Otherwise, fluent won't recognise that gambit file as a valid mesh (.msh. You can check this on the small screen underneath the main screen. Some times, t-filter fails to work because of poor mesh quality. Good luck
Old   November 24, 2002, 02:17
mahdi saniee nezhad
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Errors during exporting from Gambit to Fluent redrum FLUENT 3 August 6, 2014 23:40
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Exporting mesh from Fluent allamarein FLUENT 0 April 10, 2009 15:09
Exporting Gambit to Fluent v4 R.Wilkins Main CFD Forum 2 July 21, 1999 17:05
