Writing own turbulence model
Old   November 8, 2002, 06:08
Default Writing own turbulence model
ff
Dear Fluent users,
I would like to applay my own turbulence model by writing UDF function. Is this possible in Fluent? Any advice will be very helpful.
BR, ff
Old   November 8, 2002, 10:31
Default Re: Writing own turbulence model
cfd monkey
I think I understand your dilemma. You have the turbulence model (or the makings of one), but not the solver and some way of viewing/outputting your results. I may be wrong, but unfortunately I think it is not possible to do want you want with Fluent. My understanding of UDFs is that they are for getting more specific information about cells and faces than Fluent's defaults output. For example, if you wanted specific time-dependent data from a certain range of cells on a face, then this is a good applicaton for a UDF. Also UDF can be used for inputting profiles for velocity, temperature, radiation, et cetera, as boundary conditions. Fluent uses C in the UDFs and in Fluent 5 I'm fairly sure that no arrays are possible, among other limitations to the C language, so if this is the case, then you can see that it is probably not likely you will be able to implement a hand-written turbulence model. On the other hand, Fluent's primary turbulence models (Spalart-Almaras, K-e, and RNG) work quite well, so its probably more trouble than its worth to use Fluent as the environment to run your turbulence model. To get a definitive answer to your question, you could contact Fluent and ask them directly.
Old   November 8, 2002, 10:48
ff
Thank you, for your promptly answer. Is it possible to add some additional terms in scalar transport equations (like k or E) with UDF.
Best Regards,
Old   November 8, 2002, 11:20
Jonas Larsson
Yes, it is possible to implement a new turbulence model using UDFs. It is not easy though. You might want to ask fluent if they can provide you with an example - I remember seeing a k-w model implemented as a UDF for Fluent 5 some time ago.
Old   November 9, 2002, 23:03
david
I think, even if you are smart, it may take your 4/5 yrs of your dedicated time to implement a new turbulence model using UDFs. Why not writing a complete independent code??!! There are lots advantages and desadvantages though.
DC
Old   November 10, 2002, 06:17
Jonas Larsson
With a good example to start from it shouldn't be more than a weeks work to implement a new model and run a few validation cases.
Adding a Turbulence Model doug OpenFOAM Running, Solving & CFD 11 May 21, 2018 14:54
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
turbulence model equation Andy Chen FLOW-3D 4 January 1, 2010 22:45
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 17:15
