Time dependant discharge from a closed volume
Old   November 6, 2002, 14:56
Default Time dependant discharge from a closed volume
Chris Rand
Hello all,
I'm in need of some guidance. I need to model the discharge from a pressure vessel through a valve. I am particulary interested in the change in flow rate over time, and the time to fully discharge. My main problem is in defining the boundary conditions of the pressure vessel.
I thank you for your time, and look forward to any ideas.
CR
Old   November 7, 2002, 20:51
Default Re: Time dependant discharge from a closed volume
Boris
maybe you can have a try like this: define the pressure vessel as a separate volume in Gambit, and initialize it in Fluent with pressure,etc (you may use patching to initialize the specific volume. Hope it helps.
Old   November 8, 2002, 08:44
Chris Rand
Thanks for the reply,
Since posting my original message I have woken up! Hadn't used fluent for a while and forgot some real basics. Thanks again,
Chris
patch volume fraction in VOF at every time step... Marco FLUENT 3 January 1, 2017 13:56
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 11:46
