Compiling
Old   October 20, 2002, 21:48
Default Compiling
MON
Hello dear Fluent Users,
I am a new user of Fluent and I would like to compile a UDF (Define source (Source.Cpp)) in fluent 6.i use Microsoft Windows NT 4.after doing the steps for Building Compiled Windows UDFs using Microsoft Visual C++ 6.0( link http://www.fluent.com/support/instal...q/udfguide.htm) When i compile the UDF,i run nmake this the error message ************************ *********************** ension used : formal parameter 'port' was previously defined as a type f:\fluent.inc\fluent6.0\cortex\src\sprim.h(220) : warning C4224: nonstandard ext ension used : formal parameter 'obj' was previously defined as a type f:\fluent.inc\fluent6.0\cortex\src\sprim.h(230) : warning C4224: nonstandard ext ension used : formal parameter 'port' was previously defined as a type # Generating udf_names.c because of Source.Cpp
cl /c /Za -If:\fluent.inc\fluent6.0\ntx86\3ddp -If:\fluent.inc\fluent6. 0\src -If:\fluent.inc\fluent6.0\cortex\src -If:\fluent.inc\fluent6.0\client\sr c -If:\fluent.inc\fluent6.0\tgrid\src -If:\fluent.inc\fluent6.0\multiport\src udf_names.c Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 12.00.8168 for 80x86 Copyright (C) Microsoft Corp 1984-1998. All rights reserved.
udf_names.c # Linking libudf.dll because of makefile user_nt.udf udf_names.obj Source.Cpp
link /Libpath:f:\fluent.inc\fluent6.0\ntx86\3ddp /dll /debug /out:libu df.dll udf_names.obj Source.Cpp fl6012s.lib Microsoft (R) Incremental Linker Version 6.00.8168 Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
******** LINK : fatal error LNK1104: cannot open file "Source.Cpp" NMAKE : fatal error U1077: 'link' : return code '0x450' Stop. ************************************************** **** ************************************************** ****
My UDF is worked with interpred mode.but with compiling mode i found the error Thnak you for your help
compiling icoStructFoam error using OF1.7 mhassani OpenFOAM Installation 7 June 11, 2012 10:22
paraview 3.10.1 compiling error (1.6-ext) vkrastev OpenFOAM Installation 7 October 28, 2011 04:17
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 06:40
error msg when compiling user fortran Ollimarc CFX 0 March 13, 2008 19:16
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 sponiar OpenFOAM Running, Solving & CFD 3 February 26, 2008 07:31
