Urgent help for mixing plane
Old   October 11, 2002, 05:35
Default Urgent help for mixing plane
cherry
hello everyone:
I am carrying out a unsteady simulation for centrifugal compressor stage.in order to give a good initial condition for unsteady solution, steady simulation using mixing plane is done.the solve and boundary condition are followed:coupled-explicit solver,pressure-inlet,pressure-outlet.
when the simulation is done for some iterations ,the residual doen't go down,and mass flow rate that be monitored at the diffuser outlet change at a very small range. but the mass flow rate of impeller inlet,diffuser oulet,and the two side of mixing plane are not equal. such asinlet): 0.39389926 (outlet): -0.38044581 two side of mixing plane(inlet1): 0.8149088 (outlet1): -0.85761952 .i don't know the reason. i need your help urgently,thank you very much.
sincerely
cherry
Using a Plane id in Fluent UDF cdf_user Fluent UDF and Scheme Programming 13 October 17, 2023 01:06
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
URGENT !!! DPM & mixing plane alex FLUENT 0 December 8, 2005 11:16
