Momentum source
Old   October 10, 2002, 03:41
Default Momentum source
HDZ
We are interested in using a momentum source to simulate a pump in a time dependent flow system. It looks the information in the manual does not serve our purpose as it is not making any difference to the velocity !
How can a momentum source be implemented? The option in the 1. UDF is one possibility I believe. How involved is this option?
2. Is there another simpler method?
Thanks
HDZ
Old   October 14, 2002, 07:37
Default Re: Momentum source
Erwin
Go to boundary conditions. Select your fluid zone. Select 'Source terms'. Define your momentum source terms in the different directions. Done.
Old   October 14, 2002, 07:54
HDZ
I have done that. I have defined a limited volume of a long pipe where the momentum source has been applied but I did not get any difference.
A long pipe with an inlet velocity of say 2 m/s is set. over a certain volume of this pipe a momentum source is set in the direction,as you have suggested but somehow no difference was noticed.
That is why I equired about UDF?
Have you tried the method you suggested? Are we doing something silly there?
Old   October 14, 2002, 09:00
Erwin
I just tried it, a pipe with 2 m/s water flow and a momentum source in the middle. It worked just fine, I got a nice pressure jump.
Don't forget that the momentum source is in N/m3, so if your zone is small the source term becomes pretty big.
Old   October 14, 2002, 09:49
HDZ
Thank you very much. I will try it. I was aware of the units.
I assume that you have seen an increase in velocity aftter the momentum source, i.e. more than 2 m/s. Please confirm.
Many thanks
HDZ
Old   October 14, 2002, 10:35
Erwin
You would only see a velocity increase if the static pressure decreases a lot. The resulting density reduction would lead to a velocity increase (in compressible flow). However, I 1) used water and 2) I modeled a momentum source (not sink) so the pressure across the zone will rise. Two reasons not to see a velocity increase.
Old   October 14, 2002, 15:54
HDZ
It all makes sense now.
However it turned out that the problem we are trying to solve is a little different.
Now what would happen if you apply that momentum source to a fluid at rest? Will it give it some velocity similar to a pump?
The problem at hand is simply recirculating flow to a tank.
Old   October 15, 2002, 05:28
Erwin
I guess so. Flow is a result of pressure gradients, so a local increase in static pressure should result in a velocity in the direction of the lower pressure.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
