Fluent errors
Old   September 23, 2002, 07:39
Default Fluent errors
Stan Cornhole
Hi there, Can enyone esle substantiate a problem we seem to be having in our office. We recently moved stuff (i.e. PCs etc around), now we find that Gambit and Fluent are producing a plethora of random errors, e.g.
Gambit just disappears (with none of the usual messages about sending files to distributer)
Bus errors, segment violets in Fluent, CAR errors, display errors not pairs etc and on.
The situation has become untolerable - has anyone any suggestions (apart from), give up, accept the best of life is past and that there are no new problems to solve in science.
Stan
Depressed and Frustrated.
Old   September 23, 2002, 08:39
Default Re: Fluent errors
Erwin
Check your hardware, especially RAM chips. The biggest trouble I have had in the past was with large chips losing contact under influence of thermal stress (turning computers on/off) or simply moving it too much/roughly.
Old   September 23, 2002, 09:08
Desmond De-loutouche
I have noticed this on a system I used to be Sys. Ad for. Moved a whole batch of Unix boxes to a hotter (more direct sunlight) part of the office, and the little mokies played all sorts of heck, falling over, RAM problems esp. leading to many memory related problems for users.
Can't really offer any further help, apart from suggesting that you hold machines horizontal when moving them to stop data falling off the edge of the disk.
Dessie
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
Fluent Errors during Turbomachinery Analysis kanduri FLUENT 0 June 20, 2011 03:44
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
Fluent errors Vidya FLUENT 2 July 10, 2006 05:40
