infinite cylinder
Old   September 16, 2002, 10:47
Default infinite cylinder
Glenn
Hi, If I want to model a infinite cylinder, should I use a periodic boundary condition or (as someone told me) can I use symmetry walls?? Thanks
Old   September 19, 2002, 09:58
Default Re: infinite cylinder
Chandan Sarkar
u have to use symmetry b.c. , because it takes the vol. element as a part of the infinite cylinder and properties at the surfaces are remains same.
Thanks
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 04:56
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
infinite cylinder Glenn Main CFD Forum 0 September 16, 2002 10:49
