Whats is a shadow-wall -help
Old   September 11, 2002, 14:22
Default Whats is a shadow-wall -help
Shankar
Hello all
In the geometry I am dealing with now, which is a pipe opening into a container, both the volumes being "Fluid" zones, there is a shadow wall created for this pipe by default.What is a shadow wall and does this affect the calculations?Thanks. Shankar.
Old   September 12, 2002, 06:02
Default Re: Whats is a shadow-wall -help
Gavin
Hi, are both volumes connected correctly? Merge vertices/edges/faces then see if it changes. I have had this problem before, and could not get rid of it, so I just set the shadow face to "interior" in the fluent boundary conditions, and it was fine. Hope that helps?
Old   September 13, 2002, 02:38
Ashu
A all between two continuum is divided while reading into fluent. One wall would be the shadow wall. If the two continuum are same then it becomes interior. These two walls help in applying separate boundary conditions - like emissivity towards the fluid side of the wall. Shadow wall is also a check for internal walls created correctly or not!
You can intentionally start with a wall for any face and if the continuum are same material both sides, you can convert them into interior etc as per requirement in Fluent.
Hope this helps.
Ashu
Old   September 13, 2002, 18:20
Shankar
Thanks both of you. Shankar.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
