Problem-thermofluid+multiphase modelling?need help
Old   September 3, 2002, 01:53
Default Problem-thermofluid+multiphase modelling?need help
Ajit
Hi everybody, I need help!!! well let me describe in simple words.... A heated plate and water falling on the plate surface...the plate temperature is high and the water converts in steam.....this changes the temperature distribution in the plate.....this is a transient analysis...involves phase change....multiphase flow.....the plate has a cyclic change in temperature/power supply.......i am mainly interested in temperature distribution/steam fluid behavour/thermal stress in the plate due to this phenomenon.
can Fluent do it?? If not then what is the best way... Your suggestions will be valuable to me.
Thnx
Complex multiphase melting problem leff CFX 12 March 18, 2014 17:46
Mass conservation in multiphase problem cna FLUENT 6 April 4, 2010 11:16
UDF problem in multiphase model Amir Khodabandeh FLUENT 1 March 13, 2009 09:43
Problem of B.C. in Eulerian multiphase model Derek Jing FLUENT 0 May 12, 2002 12:52
CF4 - need advice on setting up multiphase problem Brett Towler CFX 2 August 18, 2000 17:38
