Thesis writing
Old   September 2, 2002, 12:55
Default Thesis writing
Mark
Hi all,
Anybody out there who can recommend a good website for searching research Master's thesis? Just want to get an idea of the structure of the write up.
Thanks,
Mark.
Old   September 3, 2002, 05:07
Default Re: Thesis writing
Gavin
Your university should specify the layout and structure from indexing to font. I am sure you will find something on your uni website.
Old   September 3, 2002, 06:17
Mark
I am the first student to do a cfd masters in this college, my project is cfd and combustion. So i was more interested in the layout of the cfd and combustion aspect, i.e. combustion and cfd, cfd techniques, etc. Any help is much appreciated.
Regards, Mark.
Old   September 4, 2002, 06:50
Gavin
What I basically did was:
1. Summary (outlining objectives/findings)
2. Acknowledgements.
3. Table of Contents
4. Nomenclature
5. Introduction: describe what CFD is, its uses and application ot present work. Describe your problem here.
6. Literature review: on papers of similar work, experimantal work (validation)
7. Solution procedure: CFD methods, Discretization, FVM, Solvers etc
8. Turbulence Modelling: (or combustion models in your case)from first principles describe the equations and solutiuon process, also address BL solution if appropriate.(you may need to discuss some of the chemistyr involved here)
9. Virtual Geometry: discuss how the geom was idealised and created in gambit (not too much detail), show some diagrams with and without mesh.
10. Boundary Conditions: self explanatory
11. Results: slices, plots, pathlines etc for all your cases.
12. Discussion of results: whats going on, sources of error, mesh independence etc.
13. Conclusion:Bullet points of findings
14. Further consideration: perhaps some further research that could be carried out as a result of what you have found, or if you had more time
15. References:
16. Appendix: any complex calculations you have done
Old   September 4, 2002, 07:14
Mark
That was exactly what i was looking for, thank you very much.
Mark
Old   September 4, 2002, 10:49
Gavin
Np problem, was in the same boat myself last year. What course are you doing and where?
Old   September 4, 2002, 11:37
Mark
I am work on a cfd analysis of a rotary kiln. In the Dublin Institute of Technology, Ireland. As i am the first to do a cfd masters (that i know of anyway) in DIT i have to learn it the hard way with nothing to compare it to, so your advice is much appreciated. Where did you do your work?
Regards, Mark.
Old   September 5, 2002, 13:44
sri
Hi Mark,
Did your work involve code development or using some commerial software to validate experimental results?
Regards, sri
Old   September 5, 2002, 16:24
Mark
Hi Sri,
I am using Fluent to analysis an existing kiln to try and recommend improvements that could be made to optimise the fuel consumption.
Regards,
Mark.
Old   September 6, 2002, 06:15
Gavin
Mark, done my degree in QUB and my Msc CFD in leeds, but i'm from Meath. I was not aware you could do CFD in the republic.
Old   September 6, 2002, 06:20
  #11
Mark
Gavin,
It's pretty hard to get a cfd masters here alright, i was lucky. I was at the right place at the right time. But i was planning to go to leeds if i hadn't got this. Did you manage to get a job in cfd here in Ireland?
Old   September 6, 2002, 07:02
  #12
An Modh Coinniolach
There are lots of people doing CFD in the University of Limerick. One the last people to leave here got a CFD job in the Republic.
Old   September 9, 2002, 05:36
  #13
Gavin
I had a look for a job in Ireland, but could not get one, there are many in the UK, all different applications, motorsport and process being most popular I think. CFD seems to be affiliated with Aero Eng in ireland i.e. LU and QUB, but unfortuantely we dont have much industry in that sector.
Old   November 20, 2024, 03:42
Barbara C Johnson
barbaracjohnson is on a distinguished road
Originally Posted by An Modh Coinniolach
;102561
Cisco Small and Medium Business Engineer Exam 700-750 question dumps that are 100% accurate are available from CertificationsPoint. Before purchasing, try the 700-750 braindumps in the Channel Partner Program for free.
barbaracjohnson is offline   Reply With Quote
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 09:28
journal file command for writing mass flow rate James FLUENT 0 July 26, 2006 11:51
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 09:48
Thesis writing Srinivas Main CFD Forum 1 September 12, 2002 08:39
Thesis writing Mark Main CFD Forum 6 September 4, 2002 06:28
