Fluent6.0 UDF inlet velocity BC
Old   August 30, 2002, 12:54
Default Fluent6.0 UDF inlet velocity BC
David
From wind tunnel test,we get a serial of fluctuating velocity courses along the vertical direction at the inlet in time domain ,these are random processes, and the sampling frequence is known. Could it be imposed such inlet velocity BC in Fluent6.0 through UDF? Thanks!
Old   September 1, 2002, 11:38
Default Re: Fluent6.0 UDF inlet velocity BC
sri
this can be done either through a transient profile file or by an UDF.
Old   September 1, 2002, 22:10
David
Thank you for your reply.I am learning UDF now,could you explain it more detail that how it is realized through UDF & transient profile?thanx.
Old   September 4, 2002, 12:28
sri
Hi David,
The following is a sample profile file you van use :
((david transient 4 1) (t 0 5 10 15) (u 0 1 2 2 2) )
hope this helps you.
sri
Old   September 5, 2002, 08:56
David
Hi Sri,
Thanks. My data is very large, so I am trying to import the velocity histories into Fluent through UDF by file operation. I meet a new problem now:I doubt whether Fluent could simulate this random problem. Since as the random BC is introduced, the field variables should be random process after convergence.This is an unsteady problem,but it differs from the periodical one. If, how we know it has achieved convergence when using unsteady solver?And how to get the result data?
David.
Old   September 7, 2002, 03:07
sri
Hi David,
Given a particular instant of time,the converged solution will be calculated from the boundary conditions at that time.Convergence of the solution within each timestep is important.You have to save the data files after every timestep,if you are interested and I feel this will also help you in getting some nice animations.
hope this answers u'r question!
Regards, sri
udf parabolic velocity inlet with unsteady case Faruk Beyca FLUENT 4 June 24, 2022 11:45
UDF for Velocity change at inlet haihek FLUENT 7 August 2, 2019 08:45
USED UDF for inlet velocity in 3D sara FLUENT 0 October 11, 2007 19:04
Fluent UDF load and apply inlet velocity b.c. Knut Lehmann Main CFD Forum 2 June 29, 2007 05:53
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 13:32
