why fluent can not work?
Old   August 30, 2002, 06:43
Default why fluent can not work?
anna
when i read my gambit file into FLUENT,error message is shown on the FLUEN window: "Building...
grid, Note: Separating wall zone 7 into zones 7 and 8. Warning: %thread-separate-notify: thread 8 already exists. WARNING: no face with given nodes. Thread 1, cell 8 Error: Build_Grid: grid error.
Clearing partially read grid. " I have check the mesh work in gambit, find no error, why this happen?
Old   August 30, 2002, 07:39
Default Re: why fluent can not work?
Gavin
Go back to Gambit and connect all vertices/edges/faces. Then try it again. If it still does not work check your boundary conditions and make sure they are appropriate. If that still doesn't work you may have corrupt geometry, was it and IGES import, did you clean it up? Hope that helps. Good luck.
Old   August 30, 2002, 08:02
anna
dear Gavin, so grateful for your help! but i draw the model beginning with volumes.so all vertices/edges/faces are connected. what is "IGES import"means? thank a lot for ur further help,
Old   August 30, 2002, 09:23
Gavin
'IGES import' could be like a CAD drawing, basically a geometry created in another package for example. Then you imort it in. But do not worry about it now. Its obviously a geometric problem, how many volumes do you have? If you have more than one, are you sure they are correctly merged/united? Explain your geometry in more detail please, and I may be able to help. Sometimes, if your geometry did not take long to create and mesh, its easier to start again, but you must decide that. But explain in more detail please.
Old   September 1, 2002, 11:49
sri
Hi anna,
did you make a geometry and grid check in gambit.i feel the problem is with the skewness of the mesh on your volumes.
hope this helps you!
sri
Old   September 3, 2002, 10:35
ali
hi
check your B.C in gambit you should asigne corectly any interface or interor faces between your domains if you have more than one domain like two fluids or one fluid and sold.
have fun with fluent
Old   September 3, 2002, 13:38
varghese
Dear Anna,
Some time earlier I had a similar problem. I read the same mesh file more than once and it resolved the problem. Later I found that it has to do with the computor I was using. Not a scientific solution.. but may work for you.
Greetings,
Varghese
Old   September 4, 2002, 00:00
anna
+ thanks, all dear friends. i have changed my geometry model into a simple one. it can be import to FLUENT,but the combustion temperature is not high. the original one is a little complex, a rectangle, as burning chamber, connected with some cylinders as nozzels.i used the default mesh model-cooper one,but transcript always show a warn about a uncorrect mesh.
why this happen?
Fluent does not work MASOUD FLUENT 4 April 9, 2012 14:23
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 12:21
How does Fluent RANS model work? Tang Jingwei FLUENT 6 August 22, 2009 16:08
Fluent 6.3 on Ubuntu - doesn't work adas Siemens 3 March 24, 2007 03:03
FLUENT doesn´t work ! javier FLUENT 1 February 24, 2004 13:57
