backflow volume fraction
Old   August 29, 2002, 04:33
Default backflow volume fraction
fei
I use the multiphase model,in the pressure outlet boundary condition,there is a "backflow volume fraction",i don't understand what's these means,maybe you can help me.Thanks for your help!!!
Old   September 1, 2002, 11:47
Default Re: backflow volume fraction
sri
the backflow vof is used only when there is a reverse flow at the outlet.your convergence would be faster if you give a reasonable value.
Old   September 1, 2002, 21:09
fei
thank you very much!another thing is how can get the backflow vof,may through the experiment?
Old   September 2, 2002, 04:40
sri
this value has to be intutively.when reverse flow is expected in your domain,then the value has to come from experiments
Old   September 2, 2002, 19:44
fei
your help is very useful,thank you very much.
Old   February 19, 2011, 07:29
maysmech's Avatar
maysmech is on a distinguished road
how can i set outlet volume fraction when set pressure outlet?
is it related to backflow?
regards.
maysmech is offline   Reply With Quote
Old   February 19, 2011, 12:53
Michael
VT_Bromley is on a distinguished road
In regards to this.. could the backflow volume fraction be used to restrict the seondary phase from leaving the system at a pressure outlet?
VT_Bromley is offline   Reply With Quote
Old   February 19, 2011, 14:32
maysmech's Avatar
Thanks,
So you mean if back flow volume fraction set to 1 only that phase can exit from that patch? What's your idea about above comments about backflow?
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
