Urgent help with Fluent and Tgrid
Old   August 28, 2002, 12:18
Default Urgent help with Fluent and Tgrid
dimitris
I have a problem in combining two existing meshes. My aim is to analyse the flow through a centrigugal compressor. The compressor is consisted by an impeller and a diffuser. I've already created the two meshes, for the impeller and diffuser, but I want somehow to translate the diffuser in order the outlet of the impeller to be next to the inlet of the diffuser. So my actual problem is that I don't know how to translate the two grids in Tgrid. I've read the manuals of Tgrid but I cannot find a solution to my problem. I would appreciate if anyone could give me some help or give a new idea on how to do it because I'm in urgent need. Thanks.
Old   August 29, 2002, 05:19
Default Re: Urgent help with Fluent and Tgrid
pp
Hi Dimitirs,
You don't need TGrid for translating mesh. Just use command line utility tool (type "utility tmerge") for merging two or more files. With this tool you can translate and rotate your mesh. This procedure is with Fluent6.0. In fluent5 procedure is some differnt but idea is the same (utility tools). Hope this will help.
Best Regrds,
pp
How to start 3d version of TGrid in Fluent 6.3? sangramroy FLUENT 0 May 24, 2011 01:54
[Commercial meshers] Cannot convert fluent or tgrid hexcore mesh aerogt3 OpenFOAM Meshing & Mesh Conversion 2 October 22, 2010 12:55
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Volume mesh for Fluent.. Hypermesh or TGrid?? mayur FLUENT 5 June 25, 2010 02:45
where is tgrid in fluent cfd jessica FLUENT 3 July 18, 2006 08:04
