Gambit (boundary layer)
Old   August 27, 2002, 14:44
Default Gambit (boundary layer)
Glenn
I have a boundary layer put around a cylinder (2D) in Gambit. However the connection between the outer edge of the boundary layer and the normal mesh around it do not link up. Is this just a graphics problem or will it cause inaccuracies in my calculations?? thanks very much glenn
Old   August 28, 2002, 05:52
Default Re: Gambit (boundary layer)
Gavin
I have noticed that before. Swithch off your boundary layer and look at the mesh only, it should adopt the scheme (or very close to it)of the boundary layer close to the wall. I think its purely graphical, as it has caused me no problems in the past.
Old   August 28, 2002, 12:28
varghese
Hei,
An edge meshing before the boundary layer application may help to have a better view.
Old   September 26, 2002, 02:05
Alamgir
u can also check the mesh bye examining; before that u could check after boundary layer off.
Alamgir
Old   September 26, 2002, 08:09
Glenn
I found that what I needed to do was: Create b.l., mesh edges, faces, etc. as normal Then delete the boundary layer (it will actually still be there) Then delete the face (but click off 'delete lower geometry'...you only want to delete the actual face mesh) And then, just mesh the face again (just use mesh face). The points for the boundary layer are still there but now the mesh is aligned with the boundary layer. This does actually make a difference but it is very small.
A question on "Specifying Boundary Layer Deformation Smoothing" didiean FLUENT 2 January 16, 2012 22:39
Gambit boundary layer pixie Main CFD Forum 1 September 30, 2009 13:22
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 03:02
How to use boundary layer option in gambit san FLUENT 0 May 5, 2006 01:41
GAMBIT BOUNDARY LAYER Rich FLUENT 0 August 27, 2003 15:13
