August 15, 2002, 15:58 |
Progressively Finer Mesh
I have a simple geometry. I have a simple cone with a cylindrical void in it near the top where I spin a solid disk. I would like my mesh to get progressively finer as I approach the exit of the cone. My current uniformly spaced mesh is giving significant error near the cone exit (mesh is comparatively coarse there) and thus effecting the rest of my solution. Does anyone know a simple and easy way to progressively mesh the interior of the cone such that it is denser as you approach the exit? I am using Gambit V2.0 and Fluent 6.0.12. Thanks for your help, Rupp. |
August 15, 2002, 22:21 |
Re: Progressively Finer Mesh
I think you could first go for boundary condition over the outer face (that goes thru flow direction) from exit to inlet with a growth factor more that 1. Then try for meshing that face and last go volume mesh.
Alamgir |
August 16, 2002, 05:47 |
Try the new size function of GAMBIT 2. It should help if you are using tetrahedrals.
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
