Problem with Virtual Geometry
Old   August 14, 2002, 17:05
Default Problem with Virtual Geometry
Sridhar
Dear Fluent Users,
My work involves to study flow simulations under the lawnmower deck assembly. The deck and blade geometry are generated seperatly using Pro-E . When I import them(Step files) into Gambit, both the volumes are real. I followed the cleaning process (merging faces and edges), where the real geometry is converted to virtual geometry. Now because both the deck and blade volumes are virtual, I cannot unite these two volumes(as you know boolean operations won't work for vitual geomentries). So what should I do inorder to combine these two virtual geometries?
Other question is, I want to delete the solid deck volume from the external domain,to get the region where I have to mesh(Fluid region). Because the deck part is virtual I cannot do the operation. I would really appreciate if anyone can suggest me how to handle these type of problems.
Thanks
Sridhar.
Old   August 14, 2002, 17:35
Default Re: Problem with Virtual Geometry
anna
Hello Sridhar,
you can merge two virtual volumes. But, to create the volume around the blades (your fluid volume), you will have to either create it by picking existing faces (of existing merged volumes), or by splitting merged virtual volume with some virtual vertices (or faces ?) which could be painful process.
anna
Old   August 14, 2002, 17:40
Leo
I have a little experince with GAMBIT , but i´ve had that kind of problems too. My advise is: before you do the cleanup,do all the operations that can be done only with real geometry,then procced with the cleanup and merging .This will solve your problem . Hope this helps
Regards
Old   August 14, 2002, 19:30
Sridhar
Thanks Anna and Leo.
Sridhar.
Old   August 20, 2002, 11:05
LANDA ONOKOKO
Problem with geometry sheth ANSYS Meshing & Geometry 7 August 17, 2011 10:30
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 14:31
[ICEM] Problem in geometry creation by script lavoz ANSYS Meshing & Geometry 4 March 12, 2010 11:56
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Virtual geometry faces Francesco FLUENT 0 June 19, 2006 20:38
