turbulence flow in porous media
Old   August 5, 2002, 10:52
Default turbulence flow in porous media
wei rong
Dear sir:
Can fluent model turbulence flow in porous media?
Can fluent solve primary variable on a volume by volume basis?
Thanks wei rong
Old   August 5, 2002, 11:47
Default Re: turbulence flow in porous media
Erwin
The only thing Fluent can do is assume that the standard turbulence model is applicable, i.e. the porous media has no impact on for example the size of the eddies. Therefore this is only true for porous media with porosities of maybe 0.9 to 1. If your porous medium has a lower porosity than that you could make errors when thermal or species dispersion is important. No specific porous medium turbulence models are available in Fluent.
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media flow with diffusion albertinho OpenFOAM 0 March 31, 2010 18:14
Question for modelling flow in porous media legendyxg FLUENT 9 April 21, 2009 23:24
Fluid flow in porous media question Orlando FLUENT 2 September 12, 2001 11:31
Help :Porous media flow Wole CFX 7 August 30, 2001 21:32
