Importing mesh files from Ansys into Gambit
Old   August 4, 2002, 00:37
Default Importing mesh files from Ansys into Gambit
Srinivas
Hi, I am not able to import mesh files(geometry with mesh) from Ansys to Gambit. In Gambit,in the import mesh files from Ansys option, it is asking for files with extension .FDNEUT, or .ans. In Ansys there is no option to export the files with an extension FDNEUT or ans. I would be very thankful if anyone can solve my problem. Thank you Srinivas
Old   August 5, 2002, 14:45
Default Re: Importing mesh files from Ansys into Gambit
Evan Rosenbaum
I've never tried this, so I'm only guessing, but I think you need to write a netural file from ANSYS using the CDWRITE command.
Old   August 6, 2002, 11:02
Loganathan
hai,
Evan Rosenbaum is right.Long back, I used cdwrite to export the file from ansys. The file will be with *.cdb expansion. It is called archive file in ansys.
Loganathan.E
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 07:28
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
