electrostatic force-UDF ?
Old   July 31, 2002, 16:00
Default electrostatic force-UDF ?
Zhenan
Hi
Has anybody done modeling taking into account the electrostatic force on charged particles using UDF?
Old   August 1, 2002, 03:24
Default Re: electrostatic force-UDF ?
Lanre
The magnitude of the electrostatic force is F_sub_E= qE, where E is the magnitude of the electric field and q is the charge on the particle. The electric field strength must be known. You can set constant or use a UDF to compute or apply a variable electric field.
See http://www.fluentusers.com/fluent6/d...dpm-body-force for a similar example with a magnetic force
Old   August 11, 2002, 21:58
Alamgir
Zhenan,
I'm also modelling taking into account the electrostatic force on charged particles using UDF, I'm at the very starting point. Zhenan, could you tell me which equation u r using?
Alamgir
Old   August 12, 2002, 10:33
zhenan li
Thanks for your replying.
I am using UDF to modeling the Powder Coating System. This is my first time to add electrostatic field and add electric force to charged particles.
I added the field using UDS, and want to add the force with UDF.
The equation is F = E*Q. Currently I am thinking of the constant Q, and to add this in the function. E will be from the user defined scalar.
If it answers your question?
Thanks,
Old   August 12, 2002, 21:06
Alamgir
Thanks for your reply. I'm modelling the particle tracking in drinking water with very low volume fraction. Do you count double layer effect on your modelling?
Alamgir
Old   August 13, 2002, 09:31
zhenan li
Hi;
My model is simple one. I do not consider that effect.
UDF for defining a body force in Singel ROtating Reference Frame teymourj Fluent UDF and Scheme Programming 9 August 18, 2016 16:33
Force can not converge colopolo CFX 13 October 4, 2011 23:03
UDF force on a face enry Fluent UDF and Scheme Programming 10 March 23, 2011 11:48
electrostatic force with UDF Jinfeng Fluent UDF and Scheme Programming 4 March 25, 2009 05:48
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 04:06
