Interogating Solution Values at Past Time Steps
Old   July 29, 2002, 17:58
Default Interogating Solution Values at Past Time Steps
Rupp Carriveau
I think I understand that Fluent can report "monitored" forces or field values on surfaces throughout time dependent calculations. However, I wondered if I can actually recover the entire solution (vector fields, etc.) for previous time steps in the series. I am trying to see how a flow evolves temporally. Say I solve it to the t=30s mark, could I actually go back to see what the vector field was at t=26s mark? Or do I have to solve my flow for t=26s, then t=27s, ..... , to t=30s?
Many thanks for any input!
Rupp.
Old   July 31, 2002, 03:07
Default Re: Interogating Solution Values at Past Time Step
Lanre
You have access to data from the last couple of time steps (See UDF Users Guide, FLUENT 6, Feb 2002). Anything beyond that and you'll have to write your data to a file. You could also use user-defined scalars to store variable fields, e.g., store three components of velocity with three UDS's. Use a UDF to execute the transfer of data to a UDS(e.g., C_UDSI(c,t,i) = C_U(c,t), etc.) at a specific time-step or count.
Old   July 31, 2002, 10:20
Rupp Carriveau
Thank You very much for the help.
Time step size and max iterations per time step pUl| FLUENT 31 October 23, 2020 23:50
Show solution data at certain time steps.. peresah STAR-CCM+ 13 January 3, 2015 07:54
Time step size, number of time steps and max iterations per time step guido_88 FLUENT 4 August 30, 2012 15:49
Time dependent solution Thomas FLUENT 1 January 13, 2004 10:12
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
