July 21, 2002, 22:33 |
Centrifugal force/ Rotating Wall
Hi All, When we define a rotating wall, do we have to add the centrifugal force (mw^2r or mv^2/r) to the momemtum equation in Fluent, or she does by herself ??!!
DC |
July 22, 2002, 02:40 |
Re: Centrifugal force/ Rotating Wall
You need to specify the center of rotation and speed (rad/s). Centrifugal force gets calculated automatically during solution. Ashu
July 22, 2002, 04:57 |
Are you sure you need a moving wall, and not a rotating reference frame?
The first is a boundary-condition. It applies a shear stress on the fluid at the wall. The second is a real moving zone you must assign to the entire fluid zone. You can obtain the same results, but the moving wall simulation migth take longer to converge than the moving reference-simulation. If your wall has in it's movement a component perpendicular to its surface, the shear-stress-formulation of the moving wall is incomplete to describe your problem. In that case the moving reference-frame is the only correct way. Laika, still orbiting |
December 6, 2013, 02:46 |
#4 | |
Shatrughan Jaiswal
Rep Power: 13 |
My problem related to providing centrifugal force while giving a constant rotation to the body which is a square cavity filled with water. Meshing is done by the use of Gambit and simulation is to be performed in Ansys fluent. The cavity is rotated with the origin of itself. I want to know how the centrifugal force can be provided in the fluent. Is there any UDF in the momentum source is required to define the centrifugal force? Please let me know. |
January 2, 2014, 07:30 |
Shatrughan Jaiswal
Rep Power: 13 |
thanks for your reply!!
UDF for defining a body force in Singel ROtating Reference Frame | teymourj | Fluent UDF and Scheme Programming | 9 | August 18, 2016 16:33 |
cyclone separator- centrifugal force | kumar | FLUENT | 2 | May 29, 2008 04:33 |
Difference b/t rotating wall and rotating domain? | Juno Kim | CFX | 2 | February 20, 2007 21:08 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
rotating wall | eric | FLUENT | 8 | September 20, 2003 18:49 |
