Hi all, I've been simulating turbulent flow through an annulus with Fluent and have been looking at the velocity profiles, some of which look dubious (some look asymmetric, some show a steep sides with a small flat profile in the middle). I want to compare these with 'hand calculated' velocity profiles, so does anyone know of the equation to calculate annular velocity profiles?
Watch out with flow in an annulus. Flow instabilities can occur!!
Laika, still orbiting |
Since the flow is turbulent, the velocity profile would be a correlation. I don't know of any in the literature...haven't looked yet. What is the gap to diameter ratio? If large, i.e., 1/100, use the turbulent velocity profile between flat plates as a close approximation.
There is a equation for a flat plate relating velocity, BL thickness, free stream velocity and perpendicular distance to the wall: (u/u_fs)=(y/delta)^(1/n) Usually for turbulent flows you take n=7 although some other values (8,9) are also valid. Cheers
I have had a number of issues with correct velocity profiles for simple geometries. With turbulent flows, you need to be very careful with your y+ value and placement of the 1st grid point from the wall. Use the right wall function.
Good luck with things. FLUENT 6.02 has developed new wall functions to ease the restrictions on the strict adhearance to the y+, but you still need to be careful or you will get bad results. I have actually found the most luck with the k-omega turbulence model for a RANS solver of internal flow. Matt |
Plotting Radial Velocity and Tangential Velocity in CFD Post | ashtonJ | CFX | 5 | July 13, 2015 02:49 |
User Defined Profiles, Swirl, Velocity Inlet | saurus | FLUENT | 0 | January 26, 2011 15:35 |
Velocity Profiles | Sal | FLUENT | 3 | August 2, 2007 09:06 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
turbulent velocity profiles at cylinder exit | shaheeb | FLUENT | 0 | February 7, 2006 18:00 |
