heat transfer through fluids in a pipe in pipe
Old   July 15, 2002, 09:34
Default heat transfer through fluids in a pipe in pipe
madasu
hello all,
can any body help me to find the method in Fluent to calculate the heat transfer through two fluids with different temperatures flowing though a pipe in pipe structue(conjugated flow through pipes).
thanks in advance,
madasu
Old   July 15, 2002, 11:14
Default Re: heat transfer through fluids in a pipe in pipe
Ashu
Model the structure, let's say tube&fin heat exchanger. Use inlets and outflow for both the fluids with their inlet temperatures. Solve the problem. See the temperature results.
I think you can check-up by modeling a simple two channel Aluminum/steel block with water flowing in the counter flow with different inlet temperatures.
Hope this meets your requirement. Ashu
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
Conjugate Heat Transfer at a pipe andoss CFX 5 August 17, 2009 09:54
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Ho Could I define the Heat transfer in pipe Seif FLUENT 3 June 3, 2002 13:23
