Hi, I 'am writing some UDFs for specifying some thermal boundary conditions under transient case (for example ,heat loss to ambiant, evaporation,....).However , these conditions are changing with time -we use mostlty meterological data (ambiant temperature,sky tem humidity...)witch are presented under tabular form at fixed intervals(every Dt hours). Please can you telle me what is the best procedure to read these data?
Thank you very much. Please advice me. For Example (Tabular file) Temps Humid(%) Tambiamt 1H 70 280 2H 80 290 3H 50 285 4H 90 78 .. . . . . . . . . Heat loss for ambiamt: HL(T=i:1..n)=F(Humid)*(T_face-Tambiant) for calculing HL i write a UDF Profile I want to read tabular file and compile the UDF(profiole UDF) .(these conditions are changing with time -we use mostlty meterological data) . Thank you |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
