When I read my mesh file into Fluent, it immediately gives me the following error,
Error: access: unbound variable Error Object: phase-domain? and it also changes the names of the boundary condtions set in Gambit to some default names. Can this be overcome? Help much appreciated. Thanks, Prabhu.B |
Prabhu I think you are not defineing your bounday types and boundary continnum in Gambit so define it first in Gambit and then export of Fluent. Hope this may work for you Regards Sohail
Sohail, I got all the boundary conditions and continnum types set in Gambit but still it gives me the same error when i read the file into Flunet. Any clue? Thanks, Prabhu
Hi Prabhu,
could you please be more clear....what boundary conditions and continum types you set in Gambit.... regards madasu |
Thank you for yr suggestions. I found out the reason for that error,
when I give names for the boundary conditions in Gambit, I should not leave any space between the words. Suppose I want to give a name for a boundary coditions as Pressure Inlet, I should type as as Pressureinlet, if I leave a space between Pressure and Inlet then that gives me the error. I don't know the reason, but it happens that way. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Can Fluent handle a degenerate block? Error while reading mesh... | Anorky | FLUENT | 1 | May 1, 2010 12:47 |
Retrieving files in GAMBIT & FLUENT | Vidya Raja | FLUENT | 0 | November 5, 2005 20:26 |
how to mesh iges files with gambit 2.0 ? | Lionel | FLUENT | 2 | June 23, 2004 03:06 |
Journal files of Gambit & Fluent | Arif Saputra | FLUENT | 6 | September 10, 2001 04:29 |
