how to change inlet condition in unsteady flow?
Old   July 8, 2002, 10:36
Default how to change inlet condition in unsteady flow?
bob
i want to simulate a full process of unsteady flow in a pipe with one inlet before 0.2s, when t=0.2s another wall turn to be a velocity inlet and there are two velocity after 0.2s. how to define these, i guess i should use the function of "macro", but how to set the macro?
is there anyone who will give me a advice in detail ?
regards
Old   July 8, 2002, 16:25
Default Re: how to change inlet condition in unsteady flow
Lanre
The is a tutorial (UDF Users' Guide) specifically detailing how you would go about specifying a transient velocity condition on a velocity-inlet boundary. Take a look see...
Old   July 10, 2002, 01:22
Jin-Wook LEE
I think that UDF is the only possible way.
Sincerely, Jinwook
Old   July 12, 2002, 19:52
Duc
I wasn't quite sure what you are trying to simulate, but I also think the use of UDF with unsteady flow settings may help. A good example can be found under Tutorial 4.
Transient Mass flow inlet boundary condition nikhil FLUENT 1 April 16, 2014 10:58
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 07:52
steady RANS for flow problem with unsteady inlet? kat Main CFD Forum 0 February 16, 2009 11:24
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
