DPM Modeling
Old   June 26, 2002, 10:22
Default DPM Modeling
bob S.
If a surface is set to "trap" the particle is then instantly evaporated once it strikes. This is bad if you actually want it to deposit to the surface rather than add to the fluid phase. This appears to be the the only option. Is there a way to actually trap the particle whereby its mass is then allowed to deposit onto the surface and added to the accretion rate?
(Calling the surface a "reflect" surface with a coeff of rest. = 0 doesn't work either, since the solver will not add it to the accretion in this case either.)
Any ideas?
Old   June 26, 2002, 11:24
Default Re: DPM Modeling
Lanre
Your problem requires a dual pronged approach. First, Since you do not want the vaporizing drops to participate further in the solution, use the "escape" wall bc. Secondly, you can use a UDF to keep track of your particle-wall interactions (see http://www.fluentusers.com/fluent6/d...ne-dpm-erosion)
Old   May 10, 2013, 18:40
Amir
Amir1 is on a distinguished road
Hi Lanre and Bob,
I am trying to simulate the solid partilce agglomeration on a surface in a complex multiphase flow.
I m wondering if FLUENT consider the effect of the trapped-partilces on the surface when it simulates the interactions of other partilces with the surface.
It would be appreciated if you can help me with this.
If FLUENT cannot do it should I switch to OpenFoam software?
Thanks,
Amir
Amir1 is offline   Reply With Quote
Old   May 11, 2013, 18:38
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
you set properties of a boundary regarding the dpm and change it to trapped, escaped and other setting. look up the help of fluent for more information
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 11, 2013, 21:48
Amir
Thanks for your response Ali.
Actually I am familiar with what you said but my question is that :
Can FLUENT consider the effect of the trapped particle on the surface for particle agglomeration?
I really need to know FLUENT ability about particle build up simulation.
Any idea?
DPM Modeling of high Biot Number Particles Bob Stanislawsky FLUENT 1 June 7, 2017 03:15
Modeling coal combustion with DPM Amit Katiyar FLUENT 4 November 21, 2014 06:21
dense dpm riser modeling bashu FLUENT 0 October 4, 2010 13:00
DPM modeling Mohsin FLUENT 0 March 31, 2010 23:11
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 15:49
