Adaption by Y+ on a mixed grid with periodics
Old   June 24, 2002, 07:31
Default Adaption by Y+ on a mixed grid with periodics
Martin Shanel
I experienced difficulties to adapt grid by Y+ when it had periodics. The model had rotating and stationary fluid regions with sliding periodic grid interfaces in between. The message I got was: Hanging node adaption did not conserve periodicity. Conformal adaption allows to adapt only TET cells, but most of my grid were HEX cells. I tried to delete the grid interfaces prior to the adaption, as well as changing the periodics to walls; the problem persisted when the interfaces or periodics were recreated. Anybody knows how to get around this problem? Thanks. Martin.
grid adaption mode NOT selectable via VNC Ralf Schmidt FLUENT 2 May 24, 2006 03:35
On Gradient Grid Adaption David FLUENT 2 May 2, 2005 16:50
Need help with Grid Adaption _stephen_ FLUENT 0 January 13, 2005 08:07
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Grid Adaption problems Jie FLUENT 1 February 26, 2002 12:03
