UDF syntax error
Old   June 11, 2002, 09:32
Default UDF syntax error
Duc
Hello, I am new at using UDF in Fluent, as a result, I tried create a UDF for unsteady flow, as described in the user manual. For some reason, when I try to interpret the function, it keep coming up with
Line 2: Syntax error
Can anyone suggest what I'm doing wrong? thanks in advance.
Duc ------
#include "udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position)
{ face_t f;
begin_f_loop(f, thread)
{ real t = RP_Get_Real("flow-time"); F_PROFILE(f, thread, position) = 42.41*cos(9424.778*t);
end_f_loop(f, thread) }
Old   June 11, 2002, 10:03
Default Re: UDF syntax error
Ale
You probably simply need to insert a return before DEFINE_PROFILE:
#include "udf.h"
{ face_t f;
I did it and I interpreted your code without any error message by FLUENT. I hope this can help you; anyway, I think it could depend on the C compiler you use.
Good luck, Ale
Old   June 11, 2002, 10:27
Duc
It may be something to do with my settings, as I've used the code you wrote without sucess. Just so strange. thanks for you help.
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
Why udf can not be compiled in my pc? Xinqiang FLUENT 0 June 10, 2009 15:32
