Help on simulation domain
Old   June 5, 2002, 09:36
Default Help on simulation domain
Derek Jing
Hi all,
Now I am going to model following problem: A hopper is fully loaded with small sands. The sands will flow download, go through the hopper orifice and finally fall into a tank below the hopper. The simulation will stop after all sands have flowed out of the hopper. The main result I hope to obtain is the mass flow rate through thre hopper orifice.
Now my question is: Shall my simulation domain only include the hopper itself, or include both the hopper and the tank? If I use the former, the sand mass in my domain will be less and less. If I use the later, the mass in the domain will be constant. I prefer to use the former choice, but I am not sure whether it is correct.
Can you give me some advice on using which domain? Your help is greatly appreciated.
-Derek
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
CHT Problem - Domain Imbalance Parthipan CFX 5 September 11, 2007 11:13
help on domain size that Fluent can simulation zwdi FLUENT 0 March 13, 2004 23:31
Help on simulation domain Derek Jing Main CFD Forum 3 June 6, 2002 21:21
Help on simulation domain Derek Jing CFX 0 June 5, 2002 09:35
