problem with VOF.
Old   June 5, 2002, 09:14
Default problem with VOF.
Marc
I want to modelize a free surface with a vof model. My problem is similar to the tutorial about the spinning bowl and I have adapted it to my problem. The calcul works when only the oil is in the tank (the velocity field is correct) but diverges as soon as there is water above the oil. I don't know which parameters I need to modify, their influence (and above all, how to do that): -the mesh (may be near the interface) -the under relaxations factors -the pressure (there is a pressure inlet above the air) -the iteration parameters (time step, number) -the residual monitors -the multigrid controls -...
If anybody could help me... I thank you in advance. Marc
Old   June 5, 2002, 09:17
Default Re: problem with VOF.
Marc
I am sorry: I don't use water but air above the oil.
a problem of incompressible two phases(water and gas) with VOF Method zhangweisnoopy Main CFD Forum 9 August 12, 2011 09:25
Two-phase VOF problem scott copland FLUENT 3 March 15, 2007 08:25
Problem to 'CAV' and 'VOF' in cavitation Leon Siemens 10 December 29, 2006 16:18
Problem with VOF open channel modelling Biswanath Mahato FLUENT 1 September 14, 2006 05:20
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 23:00
