Problems with linked face-meshes in Gambit 2.04 |
May 29, 2002, 09:38 |
Hello to all,
here is my problem with the new gambit version (2.04): I have a 3d-grid (similar to a backward facing step) whose lateral boundaries should be periodic. On the lower boundary (wall) I have set a boundary layer. Then I linked the to lateral faces (including reverse and periodic) My problem with the latest gambit version is that if there is a boundery layer the two periodic face meshes do not fit anymore in the near wall area although these faces are linked. In the b-l-region the meshes look somewhat distorted. In absence of the boundary layer everthing seems to work fine. Does somebody know about problems like this with the new gambit version, because GAMBIT 1.3 worked fine. |
May 29, 2002, 10:25 |
Re: Problems with linked face-meshes in Gambit 2.0
I went back to Gambit 1.3, as have many of the people I know who are doing CFD.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
unstructured grid | sreekanth | Main CFD Forum | 1 | August 6, 2001 15:09 |
Generating big meshes with GAMBIT on NT | Andrew Ooi | FLUENT | 12 | February 2, 2000 22:26 |
