Two boundary conditions on the same surface!
Old   May 27, 2002, 09:29
Default Two boundary conditions on the same surface!
varghese
Hello all,
I have a natural convection problem, in a cavity closed on all sides except at the top. I have a temperature profile on the side surface of the cavity that will induce natural convection.
I am little bit confused about the type of boundary condition I shall use for the open top surface. There is possibility of flow into the cavity as well as out of the cavity through the same surface. Which set of boundary conditions shall I use for this surface.
I invite your suggestions.
Thanks,
Varghese
Old   May 27, 2002, 10:08
Default Re: Two boundary conditions on the same surface!
Laika
Dear Varghese,
I'd use a pressure-outlet. You have to set appropriate conditions for the 'reversed flow' wich will be used when the pressure outlet is actually an inlet.
Although, if you expect significant gradients, you should take the surroundings of your cavity in your model. When you expect a continuos outflow near the walls and an inflow in the center (or the other way round) you should take a bigger domain.
greetings,
Laika, still orbiting
Old   May 28, 2002, 04:41
varghese
Thank You Laika,
Let me implement the idea. I shall tell you of the result.
Thank you very much.
Gretings
Varghese
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Boundary Conditions Free Surface friducha CFX 10 February 19, 2013 18:03
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
Boundary Conditions for internal surface Giordano Bruno FLUENT 0 January 9, 2005 13:51
