SOS SOS SOS !!!
Old   May 23, 2002, 13:26
Default SOS SOS SOS !!!
Derek Jing
HI,
I am modeling sand flowing out of a hopper through FLUENT 6 Eulerian multiphase model. I hope to monitor the mass flow rate of sand through the exit surface of the hopper.
Now I have two choices to recore the flow rate through the hopper exit:
(1) Using the panel: Solver > Monitor > Surface > mass flow rate
In this case, the obtained flow rate is for mixture or solid phase?
(2) Using the panel: Solver > Monitor > Surface > flow rate > choose solid fraction as the variable.
In this case, I am not sure whether the recorded flow rate is for solid phase.
I sincerely hope you can give me advice on how to get the mass flow rate of one of phases in a multiphase model.
Thank you very much.
-Derek
Old   May 23, 2002, 18:18
Default Re: SOS SOS SOS !!!
Jonas Larsson
Could you please give your posts a title which is a bit more descriptive?
SOS! DMFC modeling with CFD Biao FLUENT 0 August 15, 2011 15:03
SOS why this happened? whai FLUENT 0 June 27, 2003 12:38
SOS autosave unsteady particle tracking Alex Munoz FLUENT 2 June 27, 2003 01:37
SOS. Ask a urgent question Root Willow Main CFD Forum 2 October 11, 2002 22:44
SOS! SOS! SOS! Derek Jing FLUENT 1 May 15, 2002 05:25
